please help guys s10 lite vibration problem.
(Topic created on: 09-18-2020 10:43 AM)
sk04
After updating to one ui 2.5 phone is vibrating occasionally.
I have downloaded the nice catch app but it only showing vibration history from app.
Like app showing  that i have recieved notifications from insta about an hour ago but phone is vibrating now.
And also i have turned off the vibration for touch interactions , only navigation gesture vibrations are allowed .
Please help guys.
And also it is happening just after when i m unlocking the device and after that there is no sign of vibrations for a long time.
Update --- now its not happening that much frequently(by booting into safe mode, cleaning cache from apps, several restarts) but when it is happening i just want to bang my phn on floor or bang my head on the wall😑😶😤
Really need some proper fix.
And yes i have contacted with support team and yes " they are prioritising and looking into this matter"
Update- guys turn off the tools page/tab from edge panel and it seems to solve the problem of rendom vibrations.
14 Comments
Ehsank
brother go to safemode and restart your device then check
In members app go to get help> phone care> interactive checks > click on vibration. Check whether it's responding instantly or not.
sk04
it is responding instantly
Then your vibration motor is doing well. It's a software bug. Don't worry about it.
yeah...even i am facing the same problem.
Pd810
Yes the same issue. I suspect the camera is doing that. But I am not sure. It is really strange
That's ui2.5 bug..even we s10+ users are also facing it
sk04
typical samsung
Mouryan12
Same problem with Note 10 lite after updating to 2.5.
