phone doesn't fast charge when connected to a fast charger
(Topic created on: 07-25-2017 09:04 PM)
Jeswin1
I have a genuine Samsung Fast charger, a new cable. And my phone fails to fast charge. It was working fine till last morning and then this issue comes. i dont know what to do. Please help me out.28c6be67-26b0-49ac-aa4f-567ff9edb403.jpg
6 Comments
Abd53
check in the battery settings if fast charging is SWITCHED ON or OFF
Jeswin1
I did. It's ON. it still doesn't work
Abd53
try formatting ur phone and then check if the problem remains
abuals3ood
my phone its not working a fast charging
Try enabling the fast charging feature
Dear, it can be because of dirt in your charging port. Try cleaning with a little alcohol. If still not working replace your charging port.
