nougat battery s6 edge
(Topic created on: 03-14-2017 04:50 PM)
yasserahmed
Any thoughts about the nougat update and how it affects the battery ??
for me it works fine till it reaches 15% then it goes all down from 15 to 0 in very few minutes .. but after i put it in the charger it starts from 7 % not 0
any ideas??
7 Comments
Pinzo
have a similar issue...battery goes from 0 to 15% in 3 seconds !!faster than a bugati😂😂
yasserahmed
i know it's a global issue and my phone acted like that since first month i bought it .. not only me.. my brother and my friend have s6 edge with The same exact problem .. i really hoped it would be fixed it nougat update
Pinzo
is it problem with only uae phones??
yasserahmed
no .. it's a global issue.. my brother is Vodafone italy .. my friend is saudi Arabia and mine from Kuwait .. i also checked the internet and many complained about the same problem
ragnar1
you are right in have Samsung s6edge+ battery drain very quick ones it reaches 15 percent
yasserahmed
i think it's something in the software that triggers high battery consumption because i tried everything and it never wroked .. and that happens with me since First month i got the phone
Armanes
same problem here
