notification sound
(Topic created on: 08-12-2024 09:26 PM)
Tyar96
why s22 ultra one ui 6.1 notification sound stop media sound
5 Comments
Busydude
Try restarting your phone.
Busydude
These kind of things always happen after updates, so make sure to try and restart or troubleshoot with samsung.
Tyar96
still same problem
Samsung_specialist
On the Samsung Galaxy S22 Ultra with One UI 6.1, if you're experiencing issues where notification sounds are stopping media sounds, it could be due to a feature or setting that prioritizes certain audio notifications over media playback. Here are some potential causes and solutions:
1. Check if you have enabled Focus Mode or Do Not Disturb.
2. Review your notification settings to ensure that no app or notification is set to override or stop media playback. Go to `Settings` > `Apps` > select the app in question > `Notifications` and adjust the settings accordingly.
3. Some apps have their own settings for handling notifications and media. Check the settings within the specific apps you are using to see if there is an option affecting media playback.
4. Ensure your device is running the latest software version. Go to `Settings` > `Software update` and check for any available updates.
6. Simple restart can resolve unexpected behavior. Try restarting your Galaxy S22 Ultra to see if the issue persists.
Tyar96
i found the problem :
sound assistant > favorite media app.
when it's on media sound stops when i get a notification.
when it's off the media sound is reduced only
