Resolved! Solved
no notification sound on s10+
(Topic created on: 03-06-2021 06:01 PM)
seumo
My phone stopped making notifications sound
Maps_sam07
Hi seumo
Kindly check that you have turned on notifications your device.
1. From the home screen, swipe either up or down to access apps.
2. Tap Settings.
3. Tap Notifications.
4. Tap All Apps to turn On/Off.
5. Tap to turn on notification for desired apps.
Also enable your Notification Sound:
Pull down the notification bar>> tap on SOUND>> increase Notification Volume.
2 Comments
Maps_sam07
Hi seumo
2. Tap Settings.
seumo
Hi all désire app notification are on but still nothing
