bleach
08-09-2018 07:00 PM in
how can i solve this problem..???
7 Comments
Striker247
08-09-2018 10:08 PM in
Yes this issue is common globally on almost all exynos chips on S7/8 and Note8/FE after the oreo update (I've had this issue since May on my Note8). A fix is YET to be found from anyone on the internet and Samsung is yet to even admit this issue exists.
bleach
08-10-2018 03:59 AM in
That means we have to wait...!!! Is it a hardware problem or a software...??
Striker247
08-15-2018 09:53 PM in
I think its software (since it started because of a update) but apparently there's no other way to fix this without replacing the motherboard.
bleach
08-16-2018 05:46 AM in
if we change the rom than what would be tge result...??
Striker247
09-04-2018 06:18 PM in
It might work but I'm not sure. Did you fix your phone?
bleach
09-04-2018 09:00 PM in
not yet
Striker247
09-09-2018 07:59 PM in
Alright let me know if you get it fixed
