low hotspot connectivity complaint
(Topic created on: 06-05-2020 04:15 PM)
rustaq
When I share data with others using my samsung s10+ have weak connectivity / low ping. So can not use it in a gaming console very well
Could any body help me solve this issue
3 Comments
MohammedSijah
As it is "wifi" for others, lots of background activities may be there. Just enquire them. Check yours too.
rustaq
thanks for your replay Mohammed
what do you mean by enquire them
do I need to reset my phone or just clear some software?
MohammedSijah
Usually, while using hotspot, the recipients drain lots of data in the background. Especially, if they are getting a wifi after a long time. I was just mentioning that.
