in call speaker volume too much low after june update
(Topic created on: 7/3/18 3:35 AM)
sk0606
in call speaker volume is too much low after june update
2 Comments
chotasaahid
i m not able to listen the sound clearly when call is going on
admin_
Thank you for being a part of Samsung community. We apologize for the issue you are facing in the device after the update. We would like recommend some steps to overcome the sound issue:
- Navigate to settings>>Accessibility>>Hearing>>Mute all sounds>>enable and disable.
- Call sound issue also depends upon network also. Kindly follow this steps, Menu > Settings > Connections > Mobile Networks > Network Mode > Select auto mode (GSM/WCDMA/LTE).
- Kindly go to settings >> General management >> Reset >> Reset settings.
- Please run your device in safe mode.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
