Dhrumilpatel
Beginner Level 3
02-22-2020 11:27 AM in
In some apps i am not able to click ok or allow permissions because there is some screen overlay. Also, in google chrome whenever the popup appears the allow or block ads i am not able to click on block. This problem is on Samsung Galaxy s10 plus. If anybody know how to solve it please help me
3 Comments
Darushah
02-22-2020 12:12 PM in
check the screen resolution in settings. change it to FHD if not selected and then try again.
SneekND
02-22-2020 01:42 PM in
are you using blue light filter app? try ti disable and check
immi007
02-23-2020 05:04 PM in
use it in recovery mode once to see what app is causing problems. or you could reset your device once and install all apps manually and check the permissions this time. or you could reset preferences in settings which will reset all apps permissions.
