07-23-2019 10:37 PM in
Galaxy S- Mark as New
07-23-2019 10:45 PM in
07-23-2019 11:02 PM (Last edited 07-23-2019 11:10 PM ) in
Galaxy Sthis is official gcam port developer website ( XDA developers )
than carefully read the guides for s9 or s9 other exynos variants installation process
for users without android development knowledge should click suggested version link
i suggest you to look for developer code nane iDAN in XDA or in that website . he is doing work on all galaxy s series google camera mods
You can get in touch with iDAN via this link
https://www.celsoazevedo.com/files/android/google-camera/developers/#idan
there you will have his XDA profile link too
But as far as XDA irc chat with iDAN there is not gcam mod app for android pie one UI till now
you may try gcam version 5 from iDAN
07-23-2019 11:15 PM (Last edited 07-23-2019 11:15 PM ) in
07-23-2019 11:21 PM in
07-23-2019 11:23 PM in
07-23-2019 11:28 PM (Last edited 07-23-2019 11:42 PM ) in
Galaxy SFirst Read this instruction for configuration https://www.celsoazevedo.com/files/android/google-camera/f/settings09/
1. Install the app from the link below
https://f.celsoazevedo.com/file/gcamera/GCam_6.1.021_Advanced_V1.5.190418.1850.apk
2. To unlock the working features on phone model download the configuration files from the links below.
https://www.celsoazevedo.com/files/android/f/download/vkboy_S9_S9Plus_Note9_Exynos.xml
https://www.celsoazevedo.com/files/android/f/download/VAG_S9PlusExynos.xml
Notice that some features may not be available/work.
you may also try developer MGC Gcam mod too with the same config files
untill and unless iDAN donot release a gcam port , no one can say it will work properly
08-08-2020 10:18 PM in
Galaxy S?
07-23-2019 11:47 PM (Last edited 07-23-2019 11:54 PM ) in
Galaxy Slook the XDA developers report on gcam
for now get those two config import them to gcam as instructions given
