anki0012
04-11-2017 09:25 PM in
my Samsung galaxy s7 edge from when i update to nougat 7.0 my phone heat alot and probably when the phone is on performance mode. Samsung please give me the solution for this..?
2 Comments
Satsan
04-11-2017 11:36 PM in
Update has resulted in over heating and rapid battery discharge. Wish I could undo the update! SOS please
Samsung_India_
04-12-2017 03:02 PM in
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
