front camera for s8plus
(Topic created on: 08-05-2017 01:56 PM)
Arch02
anybody else facing front camera focus issues ??? specially during low light ???
admin_
"Thank you for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors.
1) Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
2) Turn on the Auto Flash (If Available in the Device)
3) Reset the Camera (From the Camera Setting)
4) Software update via FOTA,Kies or SMART Tool".
