fast wireless charging not working S20+
(Topic created on: 10-16-2020 11:25 PM)
Sam23
Does anyone have the same issue of not able to do fast wireless charging after the September patch update ?
24 Comments
yupstar23
no
Pratyušh
go in settings>device care>battery
click on charging at the bottom and se whether super fast charging is enabled or not.Screenshot_20201017-081741_Device care.jpg
Sam23
it's already on
Pratyušh
when you charge your device does it get heated than usual?
Sam23
no, it's does show fast wireless charging initially for 3-4 seconds and then shows normal wirelessly charging
Pratyušh
do you charge it wireless or with cable?
Sam23
wireless
Pratyušh
thats the reason
s20 series support 15 watts wireless charging and 25 watts wired charging so it takes half hour extra to get fully charged.i would recommend you to charge your device with cable bcoz wireless charging is not as good as compared to cable charging
Sam23
that I know but it shows fast wireless charging when connected to a fast wireless charger. The issue is that it will show fast wireless charging initially but after 3-4 seconds it reverts back to normal wireless charging.
