nikku8330
08-31-2019 11:14 AM in
Galaxy SKisi ke pas iska solutions hai kya Display half white and half warm dikh rahi hai..
3 Comments
Sidhabhi
08-31-2019 11:48 AM (Last edited 08-31-2019 11:48 AM ) in
Are you using any theme? If, then try to check this by using default theme..
And, I can see your device blue light filter is off..so that's fine..
Switch your display mode to vivid and check..also check your display screen mode settings..
70 KB
nikku8330
08-31-2019 12:38 PM in
no theme no game
anonymoususer77 683
08-31-2019 03:10 PM in
Use a different color profile. Display>Screen Mode> Adaptive Display then change the settings here until you get a clear white.
