display punch hole camera issue
(Topic created on: 10-28-2020 08:06 AM)
Dhanush2969
I have white ring kind of light emitting near the front punch hole camera of my galaxy s20 plus.
It is visible too much in dark room with low brightness and in gray or little dark background. Its annoying too much.
I don't know whether its a software issue or display problem. I don't even know whether its normal but irritating too much.
Can anyone help me know whats the issue is?
Its even more brighter than the image attached.
28 Comments
Dhanush2969
I have already removed the pre applied one and did not put any.
using it without any protection
cs-member13
Expert Level 4
Dear Samsung Member,
We request you kindly visit the service center as your device needs physical inspection. To check for the nearest Samsung service center kindly click on the link: https://www.samsung.com/in/support/service-center/
Akki294
is your problem solved.....? service center replace ur display or device with new one plz let me know....
Dhanush2969
got display replacement
HappySammy
That's funny, I have the same exact issue on my note 20 ultra and went to the service center TWICE and they refused to fix it
Members_AfedW7Y
I am facing the same problem on my note 20 ultra!! i am little bit confused is it a software issue or problem in display unit??
Kushal7
Beginner Level 5
having the same issue on note 20 ultra  
Raf12345
Mine looks exactly like yours! Makes it looks really crappy everytime I look at it.
My warranty has expired, would they still cover this, does anyone know? The problem happened since a few weeks before warranty expired and I thought it would be fixed with software update or something.
AsifSami
Was it fixed after that or you got the same problem again ?
