charging issue
(Topic created on: 05-09-2020 11:03 AM)
Krish007m
iam using galaxy j7nxt in it charging time it takes 6hrs before it was 3hrs for full charge is the problem with battery or charger in my opinion the problem is with charger's data cable because when i connect my galaxy j7nxt with laptop using charger's data cable it says (device not recognized) there is a little cut in charger's data cable and battery backup was good only the charging takes 6hrs any solution for this guys.
Can u see the little cut near the usb
8 Comments
PSYKID
The problem is with your Data cable. Consider to change your data cable.
Problem is with the data cabel
AMPK
Expert Level 3
Better to use a proper cable.
my suggestion is not use laptop for charging
Ashwin98
Only solution for this problem is changing the data cable ..
JARVISRishabH
use Branded Data Sync Cable...bro
Sundarlal05
Samsung_Support3
Dear Samsung Member,
Please be informed that  your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc.It is damaged then kindly visit your nearest service center to get it replaced.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > send feedback > error report/ask questions).
