charging issue
(Topic created on: 04-09-2022 06:49 PM)
Abhishekj
I just started noticing that my s10 lite only charges when the usb c cable is inserted one way as i change the orientation the phone does not charge as with type c cable the device can be charged both upside down and with non pd chargers the device charges normally and again if i change orientation it shows fast charging. I am on latest android 11 not updated to android 12. Is anyone facing same issues and also would like to know what are the issues with the new update as well
Update
I cleaned the usb c port using the plastic narrow side of the floss and the tissue paper but use the tissue which does not tear easily. Just slightly wet the tissue with disstled water and using the floss clean the usb c port just remember not to apply heavy pressure just with light hands and then do same with dry tissue and let the phone be still for 1hr do not instantly charge the phone to check. And the fast charging will start working.
10 Comments
BVikram
Did you try to check with different cable?.
Abhishekj
Yes as i mentioned that with type b to type c the charging works but only one side accepts the fast charging which will be 15to18 watts and type c to c it only supports one side charging while other side does not charge the device. I also cross checked with the s20 fe but there charger and cable is working properly.
Abhishekj
Type c to c inbox cable with inbox charger and type b to c refers as other cable.
BVikram
Then issue might be with type c to c that came inbox.
Abhishekj
No that same cable is working fine with the s20 fe
Abhishekj
It might be the November 2021 patch issue i guess
satishk7806
Same problem in my s10 lite. That's your charging port issue as telling by Samsung customer care. And change cost around 1700rs..
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your charging related issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
However, you can also visit bit.ly/3l9Cksp to know how to optimize mobile charging.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
rohirltag85
Using samsung m52 5gs ctype cable working one side fast charging other side not working
