battery problem
(Topic created on: 05-06-2018 11:58 AM)
bilali
everytime when I connect charger to my mobile my mobile isn't charge.and nothing show on status bar i change charger and data cable but isn't working.and some time I connect mobile with my laptop with same data cable then it work but charging to slow it takes several hours.so what should I do.i did everything I did reset setting.but nothing changes.
fhd500
maybe the adapter is broken
if you have another adapter try it with your cable if it worked then buy another adapter
