battery drains out
(Topic created on: 03-23-2017 07:14 AM)
Rash2
after the recent update .... the battery drains out so badly...... does any one notice the same.....??????
5 Comments
Subzero355
for me it seems to be ok, even sometimes it lasts me more than it with Marshmallow, but if you are facing problems with the battery after Nougat, be patient and Samsung will push an update, it would be better if you report it to Samsung itself.
Rash2
thanks for reply buddy.... but after the Nougat update the battery was fine until the last update...which is a week ago
Rani2
you are right !!!
Armanes
on s6 edge usage is barely high
1 hour 25% of normal usage
Rani2
yes ! latest update is terrible to battery !
