battery draining very fast
(Topic created on: 02-05-2021 03:52 AM)
babburyp
i am using samsung20 smartphone from last 2 months ! My battery has draining very fast all of sudden & charging has got slow !
Please suggest, how to improve battery health
4 Comments
ChandanMallick
Hello User,
The battery life of your smartphone/tablet may vary depending on your settings and usage patterns.
You can increase the battery life by optimising your settings, such as by adjusting the screen brightness or screen off time, or by turning off Bluetooth, Wi-Fi, etc. when not in use.
You can easily optimise a variety of settings by going to "Optimise settings" in Samsung Members.
After running Samsung Members, please select "Optimise settings" in the DIAGNOSTICS tab.
You can see the current settings of your smartphone/tablet, optimise each setting, or disable features that you do not use to increase battery life.
Caution. If you turn off the Auto sync feature, contacts or other information may not be synchronised with the online server and you may not receive the notifications.
Ehsank
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
rojon
Bro don't you think this is a One UI issue because not one but many people are complaining of battery drain with every update. Samsung has to do something about it.
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
