battery drain problem and Bixby also
(Topic created on: 09-04-2017 10:02 PM)
manuprasadkk
When I got my s8 last updated after all that my battery drain fastly even am not using also. then automatically came Bixby home some times. Now days am charging phone in a day 3 or more times .and full charging time are increased that time phone are over heating too much when am charging not using any applications in background Wi-Fi is off but phone getting more heating
10 Comments
Aafi1
suggest you change the setting to optimal level. delete unwanted apps and keep the phone to lowest settings. this will improve the lowers
manuprasadkk
Am already checked that way and reset the phone also no way rectify
Aafi1
it worked for me when i switched from iphone to samsung. i was having battery problem and it use to drain in like may be 2 to 3 hours from full to zero... i spent alot in chaing IC. battery at least 4 to 5 times but problem was still there. then i bought s8 and deleted everything from iphone and gabe it to my wife. shes still using it and the battery life is 7 to 8 hours lolz....still if you experience the problem then i recomend take it to the service center as the piece may be faulty
Tammam
My S8 phone battery is draining fast also after the last update .. I need to cherge it twice a day campared to once for two days before the update .. please samsung fix that problem quickly in the next update
Pu001
same problems
ishak1
hello
TajMuhammad
i have sam problem after the last updat
FatimaZahra
my problem is the battery
Neilrose
just check & clear the Cached data of your mobile. 1ad530df-5346-494b-8143-733d09f8a8a3.jpg
