battery drain in s8+ after oreo update.
(Topic created on: 04-17-2018 01:41 PM)
suyashs8
battery life has become very poor in samsung s8+(128gb) after the oreo update.before the update, battery life was still poor but now it last only upto 6-8 hrs of normal usage despite using it in power saving mode.then what is the point of having qhd+ display if i have always have to use it in power saving mode and normal display.
pls come up with a solution.
4 Comments
RickSanchez
Same situation here on my S8 :(
jebinjoseph
same here 😑
roshini96
download now http://bit.do/samsung-org-update
admin_
Thank you for being a part of Samsung community. We apologize for the issue you are facing in the device after the update. Please provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
