- Email to a Friend
02-03-2021 09:20 PM in
Galaxy S- Mark as New
- Email to a Friend
02-03-2021 09:26 PM in
- Email to a Friend
02-03-2021 09:36 PM in
- Email to a Friend
02-03-2021 09:38 PM in
- Email to a Friend
Galaxy SA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop/type C earphone only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
- Email to a Friend
02-04-2021 07:20 AM • last updated 02-04-2021 08:47 AM ) in
Galaxy Si cant wipe cache partion the truth its not going to that option once i do the same it keeps just turning on the device wat to do help???
- Email to a Friend
02-04-2021 07:22 AM in
Galaxy S(i heard for the snapdragon version the steps are different not sure)
- Email to a Friend
Galaxy S1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
- Email to a Friend
02-05-2021 08:10 AM in
Galaxy SSOT literally reduced to 4 to 5 hours 😑
- Email to a Friend
02-05-2021 08:55 AM in
Galaxy SCould anyone please have any suggestions to increase sot ?
