umi
06-04-2018 09:35 PM in
after recent security patch Samsung Galaxy S8 Plus is having an issue that it restarts itself couple of times during a day
2 Comments
kpu
06-04-2018 11:08 PM in
bro in s8 also after may update
admin_
06-06-2018 05:20 PM in
Thank you for being a part of Samsung community. We apologize for the issue you are facing in the device after the update. We suggest you to kindly reset the device once and check if issue is solved. Please do reset your device on factory mode after taking the data backup Via Smart switch.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
