Youtube fill in issue possible reason and how to solve it
(Topic created on: 11-16-2017 01:50 PM)
matrix
so recently i noticed alot of people complaining that in youtube the button that was available in s8 and n8 was gone and they no longer could go full screen
i also noticed that when i updated the youtube app yesterday it disappeared too but in my case it prompted me when i opened a vedio that you can now pinch to use the full screen mode
maybe thats why that floating icon is not there anymore as its replaced by this gesture
hope this helps ~
6 Comments
Jeet17
didnt help..but still m hvng the button
Rag1
can u pls tell me which version of youtube ur using
umi
matrix
yeah after the last youtube app update some peoples floating button disappeared
can you check if pinching in and out does the same thing for you ?
varunsahdev
https://m.community.samsungmembers.com/en_IN/view/197746?projectId=0&meta=
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
