Highlighted
I am having doubt which I haven't tried.
What happen if putting S series mobile in charge using both wired and wireless feature same time....
Mobile will do charge with any one feature or will do charging using both features?
1 ACCEPTED SOLUTION
Highlighted
if u use both wired and wireless at a time, then phone takes the wired charging not wireless.
if you are satisfied with my answer then please click 3 dots above my comment and accept solution 😊
9 Comments
Highlighted
Highlighted
obviously it will charge through wired.
Both will never happen.
Highlighted
I tried this experiment once
Highlighted
Hahaha......simple and logical,we usually accept all thing which we get easily.
can accept this as solution 😀
Highlighted
Highlighted
simple it will charge with wired charger only...battery charging port also act as data transfer port..if you apply charging through it with wire then voltage will directly transfer to main receiver of battery voltage gated channel so it's fast than wireless which recever connected at back side of battery
Highlighted
😂😂 primitive way to charge up the device
wireless charging is better than wired charging
Highlighted
according my theory for most better battery life, turn off fast charging option and charge battery normally..may it will take some time but battery will be fine for long
Highlighted
I use wireless charging only because it allows me safety against dangerous spikes of current more over even if my usb port shows the error of moisture that does not effects me to charging my device
