Wifi connectivity Issue
(Topic created on: 04-29-2020 09:11 AM)
MShrafat
Beginner Level 3
My s10 plus can't capture weak wifi signals even years old samsung s7 can do that.
Any one else is facing the same issue or i have to go for service center
I like this 512gb beast but.... kinda like wifi too
Please guide
Yes i have performed factory reset after update.
4 Comments
DrShahid
This issue start after s7 after s7 each samsung device at same distance at which s7 it capture that WiFi signal but other devices like s8. S9 and even S10 have same issue.. Not capture that WiFi even not show that WiFi at which s7 connected
MShrafat
Beginner Level 3
so note 10 plus would have the same problem 🤔
DrShahid
Yes Bro m samsung user almost all series start note 4 and now S10. This issue start after s7.
MShrafat
Beginner Level 3
i think latest update fixed WiFi connectivity
