Wifi calling issue while using private dns
(Topic created on: 05-10-2023 03:16 PM)
spidy269
I am using private dns to block ads and wifi calling is not working on jio sim service, when I turn off private dns then only my wifi calling is working. Please sort this out to make enable wifi calling service on jio sim while private dns is enabled.
4 Comments
Why are you using private DNS?
From which app you want to block ads?
If you only use Chrome and want to block ads then follow this link. Then you will able to make calls over WiFi.
https://r2.community.samsung.com/t5/Tech-Talk/Tips-to-block-ads-in-Chrome/td-p/13368564
Hmm this is the issue but you can use this method as alternative.
cs-member11
Dear Samsung Member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Note. please attach the error log file within 15 minutes of the error occurring.
Rushabh22
Did you find any solution?
spidy269
Jio + dns is not working
But
Airtel + dns no issue at all
