Why does the battery decreases on the S7 edge???
(Topic created on: 10-05-2017 07:29 AM)
TrigonalEvolution
It's a very good question!!!...So..The reason is, When U update yur S7/S7 edge to android nougat(7.0), It uses a lot of yur data usage on the background and on apps also...So, I advise you to put data saver ON. It will really save your data
