White light blinking just above battery percentage
(Topic created on: 03-17-2019 04:46 PM)
sishan21
Hello,
I'm using S10 plus. There's a white light blinking in the screen when i make a call just above battery percentage indicator. What is it?
4 Comments
Not applicable
proximity sensor
sen001
It's the proximity sensor. You must have been on a call. Try to put your hand over it, it will turn off the display.
sishan21
Thanks, man!
I didn't know they are putting sensors under display nowadays
that's the new tech
