Whenever i use my mobile[A 21 S] it restarts..What's the problem??can any tell
(Topic created on: 01-04-2022 07:06 AM)
Alexenderkhan
7 Comments
First factory reset it then see its good or no
Alexenderkhan
Resetting is very difficult because almost 60GB is full..
So it's not possible 🤔
Bro use sd card to good performance of phone
Alexenderkhan
Ok bro😍
hubali
Check your battery 🔋
Alexenderkhan
No problem from battery because it work very properly means no restarts using in safe mode...
It maybe other reason..
Bro finish safe mode
