4 weeks ago in
Galaxy S- Mark as New
4 weeks ago in
Galaxy SDear Samsung Member,
● Update Your Device's Software: Settings > Software update> Download and install> On-screen instructions.
● First Check Your Internet Connectivity: Most of the time, Google Play Store errors are caused by intermittent or slow internet. If you are on mobile data, try to connect the device to a strong Wi-Fi network. If Google Play Store is not downloading while you are connected to Wi-Fi, you may need to troubleshoot your Wi-Fi first. The general rule is to ensure that your phone has a stable internet connection before you start to download anything from the Play Store app.
● How to Check Internet Connectivity: If you are connected within a Wi-Fi network, you may find Wi-Fi status on the bar whether it has strong or weak internet connectivity. If you are using your mobile data, you will need to ensure that you have enabled mobile data via your Quick panel. Follow the steps below to check your mobile data available.
● Path: Quick panel> Turn Mobile data on.
Note: Google Play Store downloads only one app at a time. If another app is being installed or updated, wait for it to finish or stop.
● Check Enough Space on Your Storage: Settings > select Device care>Storage > tap on Advanced at the bottom of the screen> Check Available space> If your device has less than 1GB of storage available, you will need to free up some space. For example, you can back up your pictures and videos on the cloud and then delete them, or you can delete unwanted apps for more space.
● Clear Data and Cache of Google Play Store: Settings> Apps>Google Play Store> Storage > Clear data or Clear cache.
● Remove and Set Up the Google Account: Settings > Account and backup>Tap Accounts > Google account> Tap on Remove account.
● Restart the device: Press and hold the Power button until the menu pops.
Tap the Restart button and wait for the device to power off and on again.
● Kindly try to connect the specific application once to make sure there is no issue from there end.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
