Volume control
(Topic created on: 10-12-2021 12:07 AM)
AbuAmmar
Sound volume control is better if it is coming down and close to the thump
6 Comments
ProgRidha
You can move it using good lock applications through sound assistant Screenshot_20211013-093628_Good Lock_38894.jpgScreenshot_20211013-093638_Sound Assistant_38895.jpg
AbuAmmar
Thank you for your reply, but it will be better if it can be done through Samsung UI
ProgRidha
My pleasure brother yes brother but since the mentioned good lock application is made by Samsung so it's trusted and it won't do any harm 👍
AbuAmmar
Thanks a lot, it works and really fantastic
ProgRidha
My pleasure brother 🙏🙏
MohammedSijah
Also try "One hand operation+" another precious app by Samsung.
