SL09
Edge screen should feature volume control. This will avoid clicking the volume button, which is placed high up.
Also virtual power button in notification panel will be good addition.
8 Comments
poudelsujan920
You can get volume control and virtual power botton from assistant menu . Try it 😊
SL09
Suggestion: Assistant menu should be incorporated in edge screen.
poudelsujan920
Yes write request messages to samsung team regarding this topic 😀
SL09
Where do we do that?
poudelsujan920
You can do that in samsung members app
SL09
Yes done,
Thanks
poudelsujan920
Welcome
Edwin7878
Its already there checkout on setting << display << edge panel<< panel<< more panels and u can find many panels to download ..
But It's paid 😓
https://apps.samsung.com/appquery/appDetail.as?appId=com.imagineer.edgevolume
Bro use onehand operation+ goodlock modules ..
With that u can control volume without pressing volume buttonclipboard_image_1634632914381_1634632914381.jpg
