Vibration for calls not working
(Topic created on: 01-02-2023 03:39 PM)
PanicX
Beginner Level 3
On my Samsung Galaxy S10 running OneUI 4.1, my phone suddenly isn't vibrating anymore for calls. Messages are vibrating though. I tried resetting settings and even clearing cache from recovery but to no avail.
Anyone can help?
5 Comments
Amrmzr
Try soft reset by pressing and holding power + volume down button until your phone automatically restarts and Samsung logo showed up then release the buttons.
Infinity53
Expert Level 4
Just restart your phone and then check. Hopefully it will work.
PanicX
Beginner Level 3
I tried both soft reset and restart but it's still not working
Amrmzr
Hi greetings!
Remove your sim, turn on flight mode and after 10 seconds soft reset your phone. Then change your ringtone to none then change to whatever you like with sound and vibration enabled. Lastly restart your phone and check.
Amrmzr
Still didn't work report your issue to Samsung through error reports.
