07-13-2025 06:32 PM in
Galaxy S- « Previous
- Next »
07-13-2025 06:43 PM in
Galaxy S- Mark as New
07-13-2025 07:01 PM in
07-13-2025 07:40 PM in
07-13-2025 07:41 PM in
07-13-2025 09:38 PM in
Galaxy SYou'll blow up your battery within a couple of years.
You need to use your device in an optimistic way.
To do this:
You can do the following things which won't affect your experience much:
1. Set a routine to turn ON power saver automatically when battery level is below certain level, say 45%.
2. Set Performance profile to Light as it doesn't affect day-to-day normal usage. [For Galaxy S Users]
3. Disable Adaptive Brightness as it uses the sensor and battery all the time.
4. Keep less screen time out.
5. Use Dark Mode.
6. Turn OFF Nearby Device Scanning.
7. Turn OFF Location, WiFi, Bluetooth scanning. They consume a lot of power.
8. Enable auto restart when needed.
9. Regularly clean your memory.
10. Disable RAM Plus if you don't require much memory hungry apps.
11. Uninstall the unnecessary apps which you don't use.
12. Put restrictions on which apps can run in background and which should be put to Deep Sleep.
13. Turn OFF notification from the apps you don't use much or don't need or which send you useless Notifications. They drain a lot of battery running in the background.
And one thing, i think you're messing with is the thermals if your S23 FE.
Don't let your device go beyond 40°C.
Put the phone on charge only when it's cool, to do this turn off Wifi, Mobile data, Location, Bluetooth, etc. For 10 min, before putting the phone on Charge.
After a charge is complete, let the device cool down for 10 minutes, after that only start using the device.
Never use the device while charging, it heats up the device causing slow charging and damage to the battery.
If this helps you, I'll appreciate if you could accept my comment as solution by clicking on the dots on the top right of my comment 😊
07-14-2025 09:19 AM in
Galaxy SDear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request that you visit our service center. Our technical team will be able to inspect your device physically and provide you with detailed information and assistance.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
07-14-2025 01:21 PM in
07-16-2025 11:27 AM (Last edited 07-16-2025 11:28 AM ) in
08-18-2025 06:55 PM in
- Next »
