USB - Headphone or USB-C to 3.5mm headphone not supported
(Topic created on: 09-01-2021 10:56 AM)
Epichunter
Hello Galaxy Family do you had any issue as like  me with S21 Ultra?? I've faced issue with USB-C HEADPHONE AND USB-C to 3.5mm headphone. That system message shows me not supported.
#Community Manager could you give me some advice how to use type c headphone with S21 ultra?? Or Samsung blindly forcing me to use their galaxy buds ??
7 Comments
Hi there, have you tired an original Samsung USB-C headset?
Epichunter
Nope
HUZAIN
Same brand type c earphones and earphones connectors not supporting. Try Samsung original type c earphones
Epichunter
OK
MohammedSijah
Cheap usb-C s work with only some devices. I had the same experience while connecting otg and some adapters. But the original will defnitely work.
Epichunter
Thank you for your comments
Alphazor007
Samsung requires headphones or 3.5mm connectors with DAC support to properly work. Cheap "made in china" connectors and headphones are not supported. Make sure that you buy official Samsung products or other supported and name brand products for a better experience.
