Too much ui problem
(Topic created on: 05-31-2024 05:38 PM)
mleet
My phones been acting up alot and it couldn't start and the ui had too much trouble apps appearing inside other apps and alot of messy stuff from a new flagship phone(s23 ultra) i couldn't even see the quick panel and my phone started having those troubles ever since last week since i updated my phone software
3 Comments
mleet
Ps: i checked the last time i updated and it was last week so the problem is with the new software update pls fix
Samsung_specialist
Follow these steps if you wish to Wipe cache partition, which can solve the issue:
Turn off the device.
Press and hold the Volume Up key and then press and hold the Power key .
When the Android logo displays, release all three keys.
An 'Installing system update' message will show for 30 - 60 seconds before the Android system recovery menu options appear.
Press the Volume down key several times to highlight wipe cache partition.
Press Power key to select.
Press the Volume down key to highlight yes, them and press the Power key to select.
When the wipe cache partition is complete, Reboot system now is highlighted.
Press the Power key to restart the device
mleet
Thank you
