Title: Low sound output in One UI 8
(Topic created on: 10-07-2025 10:34 PM)
Dhurup1234
Hello Samsung Team, i am using the Samsung Galaxy S24 Ultra with One UI 8. I have noticed that the sound output is very low during gaming and while listening to songs or media. The volume seems significantly lower than before, and the audio clarity is not satisfactory. I request the team to please optimize the sound performance in upcoming updates so that gaming and media experiences are improved. Thank you for your attention
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
