System UI Not Responding
(Topic created on: 12-17-2023 05:57 PM)
Cratus
Beginner Level 4
Now a days after Android 14 Update In my Galaxy S23 I am regularly facing this issue of System UI Not Responding so many times and the device gets hanged for atleast 10-15 min I can't use it please rectify this issue My device is under warranty also.
3 Comments
MadhuT07
Restart your phone , and clear storage
cs_member10
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can check the device in safe mode and for the safe mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue persists, kindly share the report of the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
save battery in samsung
go to setting
1. sound and vibration then system sound then off all sound and go back and system vibration then off all vibration
2. notification then app notifications and off all unnecessary app notifications
3. display than on dark mode
4. display than off adaptive brightnes
5. advanced features than labs off all experimental feature
6. advanced features than motion and gesture off all
speed up your samsung phone
1.first go to setting then
2.about then
3.software information then
4.tap 7 time on build no then
5.developer option open then
6.go back in setting app and
7.last one is developer option then
 8.find three type of animation
9.first window animation scale- set off
10.second transition animation scale- set off
11.third animation duration scale- set .5
second tip
go to setting than
display than on touch sensitivity
set samsung mobile camera for best click
first open camera app
tap setting icon
on high efficiency picture
on save selfies as previewed
then setting to keep option
on filters
then go back
tap on filters select ivory -4
than face filter
then tap off/auto
set smoothness-8
set tone - 4
