ShoCkWaVe
β12-15-2018 09:39 PM (Last edited β03-16-2019 05:01 PM ) in
Hi guys, I have an s8 which is roughly 13 months old. I have installed the November security patch.i was using the phone and the battery drop to 15 then suddenly, in less than a minute, the battery dropped rapidly to 4 %. ππ. Have you guys experience this issue and of so what must I do to fix it?
Rest of the phone is awesomeππ½ππ½ππ½ ...I have nothing else to complain.
Cheers
Cheers
5 Comments
JUMMAN1987BANGL ADESH
β12-15-2018 09:47 PM in
my sensor not working after the update
ShoCkWaVe
β12-15-2018 10:03 PM in
ohhh i dont have anu idea aboutthe sensor but have u faced this battery problem
sauravvishwakar ma030
β12-15-2018 10:22 PM in
use the code *#0228# then press calibrate and wait for 10 second your screen will turn off and automatic on then it will show the correct battery level
sawan07
β12-16-2018 01:45 AM in
I am having a S9+. Same issue with me. Can't understand what is going on
kpu
β12-16-2018 11:42 PM in
same here bro
