03-12-2020 08:19 PM in
Galaxy SSolved! Go to Solution.
5 Solutions
03-12-2020 08:25 PM in
Galaxy S- Mark as New
03-12-2020 08:27 PM (Last edited 03-12-2020 08:36 PM ) in
Galaxy SPut all apps to sleep from device care.Keep an eye on apps which are running in background from Settings>Developer Mode>Running Services>Force stop unnecessary apps. Also do a cache wipe from recovery mode.
If issue isn't resolved then maybe there are bugs in latest update so you need to wait for a bug fix update.
03-12-2020 09:15 PM in
Galaxy SDo that if no trick works. Download Kill apps named apps from playstore which force stops apps
03-12-2020 09:42 PM (Last edited 03-12-2020 09:47 PM ) in
03-12-2020 09:58 PM (Last edited 03-12-2020 09:58 PM ) in
03-12-2020 09:56 PM in
03-12-2020 10:01 PM in
03-28-2020 07:43 AM in
Galaxy Si done factort reset and safe mode restart didnt worked.
i checked no apps were using the battery
03-28-2020 08:37 AM (Last edited 03-28-2020 08:37 AM ) in
04-04-2020 01:03 PM in
03-12-2020 09:58 PM in
