Sreen and battery
(Topic created on: 04-09-2022 02:48 PM)
Bablee001
My 4 days s22 ultra has screen problems..also its battery is draining so quickly
10 Comments
Screen problems? Like?
For battery check if you're running the latest software.
Also disable bixby voice..
In setting check what apps are eating the most battery. Then you'll be knowing how to fix and what to fix.
Bablee001
Sometimes the screen switches off while I'm using the phone..or it won't respond while i type..yes I'm running the latest version..
CrissStef
Mine too. Especially if i am in a call, i can't get my screen to on and can't access anything during the call. Also the screen sometimes seems irresponsive to touch.
Seanus
Try to call samsung or message them
Bablee001
How
Seanus
Using the members appScreenshot_20220409-224711_Samsung Members_31787_1649530032.png
Seanus
Text chat or just call them if you want Screenshot_20220409-224756_Samsung Members_31788_1649530076.png
Bablee001
Thank you brother
CrissStef
Mine too. Overheating and battery drains super fast
