XYRO
05-30-2018 09:34 PM in
admin_
06-01-2018 04:07 PM in
Thank you for being with Samsung and sharing your concern. We would like to offer some troubleshooting steps to overcome the issue:
1) If Problem is existing on the Call. Check the Network mode setting (preferred GSM Only network mode) because some time sound problem can be occurred due to N/W problem
2) In Android JB or above check (disable) the Turn off all sounds option by navigating into Setting-->Accessibility-->Turn Of all sounds
3) Decrease the volume and then increase it again & avoid lamination on speaker.
4) Check media sounds and system sound by navigating into Setting-->sound setting-->volume
5) If problem still exist run the device in Safe Mode
6) if it still not working please reset the setting of phone by navigating into Settings >> General Management >> Reset >> Reset Settings >> Reset Settings
7) Periodic Software Update through FOTA, SMART SWITCH or Smart Tool is intended to resolve the issue as well.
😎 If the issue still persists create full Data backup & Factory reset the device.
Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
