07-20-2025 01:07 PM (Last edited 07-20-2025 01:08 PM ) in
07-21-2025 11:00 AM in
Galaxy SDear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
