Sound issue
(Topic created on: 09-24-2023 02:43 PM)
malik477
Hi dear samsung my s23 ultra rings automaticlly without showing any notification on dispaly it randomlly starts ringing i dont know whats the iasue it may be software bug please fix it
7 Comments
alenjorj
Is it ring tone or notification tone?
malik477
Ringtone
alenjorj
Restart your device maybe it will ok
Restart you device if not check sitting
AXTTECH
Try reseting settings
Samsung_specialist
Kindly make sure that the phone is updated to the last software version, then try to reset all the settings from the settings >General/ General management> Reset > Reset all settings.
malik477
Done thanks 😘
