12-09-2020 10:00 AM (Last edited 12-09-2020 11:52 AM ) in
Galaxy S- Mark as New
12-09-2020 10:11 AM in
12-09-2020 10:14 AM in
12-09-2020 10:20 AM in
12-09-2020 11:26 AM in
12-09-2020 11:27 AM in
Galaxy Ssettings>applications>click 3 dots at top right corner>select reset apps preferences
also check recently installed apps
Go to applications>click 3 dots>select show system apps>select settings apps>clear cache
12-10-2020 09:11 PM in
Galaxy SDear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
02-07-2021 06:39 PM in
Galaxy SHi, I had similar problem on Galaxy Note10, and couldn't solve it after going to safe mode. The difference compared to thw described from previous user is that when I tap on sound and vibration item in settings, it just close the settings screen and move me back to homw screen. Please advice.
02-07-2021 06:46 PM in
