Sound and vibration toggle disappears
(Topic created on: 09-12-2025 01:31 AM)
GyroDeath
Hi all,
I use a S24+ with a model SM-S926B with oneui 7.
I noticed that When i want to receive notification in silent mode for a particular app i can do so by turning a toggle off called sound and vibration, but that entire option disappears and i cannot turn it back on after that.
Screenshot when toggle was on:
Screenshot (for a different app but this happens for all the apps) after toggle was off:
11 Comments
Akshunegi
Hii... if you find the solution please share here also
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Surya230
You are telling him to reset the phone, seriously! 😖
Surya230
You are literally giving false solutions. 🤦
GyroDeath
Haha it's ok. I won't do that as I know it will not work. Atleast they tried.
Surya230
He's pretending like an Expert but actually he's dumb. 😐
goodthings
You're welcome to here.
DINKAR_A34_5G
Go to Settings > Apps > Reset app preferences.1757671494831.jpg1757671494894.jpg
GyroDeath
Thanks, it does reset preferences for all apps, but the issue does not get resolved as when I turn off the toggle it happens again.
