Sound Quality Issues/Distortion
(Topic created on: 10-03-2022 08:40 AM)
iMAjay
Alright! So I have recently switched to brand new S22+ from 1-year-old-S21+ and I have been experiencing sound quality issues. The sound from both the speakers sounds like extremely high pitch noise with hardly any mids or bass & getting distorted if I volume up. This gets even worse when I turn on the Dolby Atmos to listen music through my phone's speakers. However without Dolby Atmos, it's kind of a little acceptable. Also the videos on YouTube is doing great job.
To be honest, this is the worst Sound Quality I have ever experienced in any of the flagships from the Samsung. Even worse than my 4 years old Galaxy Note9.
What should I do now? Any suggestions or fixes?
11 Comments
deep10371
I'm not facing any type of issue
CODM6567
No such issue with mine unit
iMAjay
Getting proper mids & lows on loud speakers?
CODM6567
Yes but if volume is above 90% then distortion is there. Same experience with my tab s7 too. If volume is more than 80% then distortion is there. I think this is normal.
iMAjay
In addition to this, when the volume is in the middle, sound it too low considering its level. Is it normal?
deep10371
Yes
iMAjay
You too experiencing the same issue? 🥲
deep10371
Nope
PRASSANTH
Even I'm facing this issue and what about ui in my case it's very laggy 🥲
