Solved Battery Drain Problem after ONE UI 7
(Topic created on: 05-21-2025 03:11 PM)
Haazim
All those who are experiencing the battery drain after the ONE UI 7 update, you just need to do a factory reset ( after backing up all your data ).
After every major OS update it is always advised to do a complete factory reset your phone.
Hopefully, it will solve the problems.
14 Comments
captain-cj
I had reset my device and it has been 2-3 weeks, battery still drains.
Istayhere
that's my only concern.
I don't think it's works like that.
if it was fixed it will be immediately, we don't have to wait for weeks or reset our phone just to fix that because the software will be same which was before resetting phone
captain-cj
Which devices you are using?
Haazim
S24 Ultra
kulbeers2
What is your avg screen on time ?
Istayhere
so that fixed your problem?
Haazim
Yes it worked for me.
Istayhere
so what about the data? you backed up with samsung cloud?
Haazim
Nope i used Samsung smart switch to backup it on laptop. You can do it anyway you find it easy.
